Small issue with denon hc5000
Finally got it working again after the denon controller issues.
Using WASPI and putting sound to 44100 in vdj settings
Now the issue is I am getting clicking sounds In the audio output. It is a constant odd sound while playing the music
Any other settings i have to change????
Thanks in advance.
Thanks in advance.
geposted Fri 19 Jul 19 @ 10:20 am
buffer settings too high? Checked your usb cable or replaced? moved to a different usb port?
geposted Fri 19 Jul 19 @ 1:58 pm
I think I i figured it out. Put exclusive audio access to NO and all sounds good hmmmm.
Clicking went away.
Clicking went away.
geposted Sat 20 Jul 19 @ 12:11 am
Try putting a ground canceller on your laptop power cable. That is the connector that makes it a 3 prong to 2 prong.
geposted Thu 25 Jul 19 @ 1:24 pm
Clicking went away.
Clicking went away.
I had the same problem when I selected this setting with my denon mc4000, it was clicking like every second.. I was trying the WASAPI drivers over the ASIO but I can't use the cue with WASAPI so back to ASIO.
geposted Tue 30 Jul 19 @ 5:23 am
