I thought I ask in the forum so the info is there for all to see.
1 How do I make a plugin work as a colorfx ? (I tried assigning but the label stays dim)
2 how do I make a slider effect_beats ? (can I have more than 1 per effect)
That's it for now till I think of more.
geposted Tue 23 Jul 19 @ 12:04 pm
I think the current sdk download still misses these, but you can add the following to vdjPlugin8.h
The list of color fx (filter_selectcolorfx) is curently hardcoded, so you can't get your plugin in the drop-down yet, but it will probably work specifying the effect
filter_selectcolorfx "myeffect"
Then you just have to monitor the parameter you declared as color fx.
You can add compatibility with effect_beats by declaring some a Beats and BeatsRelative parameter, and then handling these parameters when changed.
#define VDJPARAM_COLORFX 7 //similar to slider, but with default position at 0.5 and only one per effect for single-knob full control
#define VDJPARAM_BEATS 8 //float specifying number of beats
#define VDJPARAM_BEATS_RELATIVE 9 //int, set to +1, -1 etc to move the number of beats higher or lower when OnParameter is called
HRESULT DeclareParameterColorFX(float *parameter, int id, const char *name, const char *shortName) { return cb->DeclareParameter(parameter, VDJPARAM_COLORFX, id, name, shortName, 0.5f); }
HRESULT DeclareParameterBeats(float *parameter, int id, const char *name, const char *shortName) { return cb->DeclareParameter(parameter, VDJPARAM_BEATS, id, name, shortName, 0.5f); }
HRESULT DeclareParameterBeatsRelative(int *parameter, int id, const char *name, const char *shortName) { return cb->DeclareParameter(parameter, VDJPARAM_BEATS_RELATIVE, id, name, shortName, 0.5f); }
geposted Tue 23 Jul 19 @ 1:26 pm
A quiet moment; is there anything to add to the API for things that have recently gone public, mixfx being an example?
geposted Tue 24 Sep 19 @ 10:17 am
MixFX are similar to Color Fx, so a custom one will currently not show up in the list yet, and you'd have to select it by name yourself.
The transition effect is applied to both decks. It will move from 1 to 0 on the deck mixing from, and from 0 to 1 on the deck mixing to.
#define VDJPARAM_TRANSITIONFX 12
HRESULT DeclareParameterTransitionFX(float *parameter, int id) { return cb->DeclareParameter(parameter, VDJPARAM_TRANSITIONFX, id, "Transition FX", "Trans", 0.f); }
geposted Tue 24 Sep 19 @ 10:29 am
Thanks for that, I think this might make for some interesting things.
geposted Tue 24 Sep 19 @ 10:45 am
