Forum: Wishes and new features
Topic: Click and move
Once clicked any button, specially exit but not only this one the actiopn is to be executed
Any application allow to move the pointer to select another button or none and apply the last pointed action
where VDJ does not allow any mistake and take in consideration the action at pressed, not the one at release
Would be fine being able to change idea specially for the close, delete remove ones
geposted Sat 27 Jul 19 @ 10:28 am
None of the common controls work according to any standard. There are standards for these things so people can move from one program to another and get similar behavior without having to learn variances. When these are not correct, it immediately says amateur to anyone that knows what they are looking at. If you want to change the behavior have options for doing so.
