How can I use echo out on Virtual Dj?
geposted Mon 29 Jul 19 @ 1:02 am
Standard echo effect can be used as echo out
You may use the "Mute Source" button in the Gui or in some skins
or create a custom button to toggle mode :
effect_button echo 1
or if you want to experiment... some customized versions like "echo on + on release echo out & stop" :
effect_active echo on & effect_button echo 1 off & up ? effect_button echo 1 & repeat_start ec 5000ms 1 & stop_button & effect_active echo off while_pressed
do not forget to preset filter lowpass & hi pass filters
geposted Mon 29 Jul 19 @ 2:08 am
