I'm certain I've asked this before (maybe in a dream) , is there a way to have a 'Waveform Only Mode' in these plugins?, no title, no artist - just the waveform?
geposted Sat 03 Aug 19 @ 12:14 pm
How about if you use the hide feature?
geposted Sat 03 Aug 19 @ 1:42 pm
it works just if you want to hide the song info but the current song and the words hidden are still on view as are the lines, i just want the waveform only
geposted Sat 03 Aug 19 @ 2:44 pm
As far as I'm aware, the only way is to edit the videoskin (you can 'comment out' the unwanted code).
It would be nice if the videoskins could have a hidden or disguised button to switch stuff on/off like standard skins.
geposted Sat 03 Aug 19 @ 3:48 pm
It is possible to add a visibility parameter field to unwanted panels related to a global variable and a custom button/pad to control it
geposted Sat 03 Aug 19 @ 4:04 pm
Example please.
geposted Sat 03 Aug 19 @ 4:32 pm
groovindj wrote :
Example please.
yes, example please, I'm no skin wizard and 95% of what @Nicotux said went over my head
geposted Sat 03 Aug 19 @ 4:35 pm
in A Horisontal Titler demo [wallpaper example].xml :
line ~=14
<group name="text" x="80" y="580">
<panel visibility="get_var $disable_songtitle">
<textzone group="horizontal" align="left" deck="master">
line ~= 40
</textzone>
</panel>
<equalizer type="bar" nb="96" color="#ffffff" deck="master" width="0.4" slow="true" bass="middle" mirror="false" >
and the button :
toggle $disable_songtitle"
line ~=14
line ~= 40
</textzone>
</panel>
and the button :
geposted Sat 03 Aug 19 @ 4:59 pm
I just had a look at UX1 (Titler White Transparent) and you'd need to remove or comment out lines 13 to 38 - basically everything after the 'video' and 'visual' section, to before the 'equalizer' section at the bottom.
You can comment out by using <!-- before the section and --> after it.
geposted Sat 03 Aug 19 @ 5:04 pm
Thanks Groovindj, I've not done this yet but will do soon
geposted Fri 30 Aug 19 @ 4:10 pm
UPDATE: Just tried it out and it works perfectly on Minimalist 2 Circle titler white (transparent)
and Horizontal Titler White (transparent
geposted Fri 30 Aug 19 @ 5:19 pm
Well done!
geposted Fri 30 Aug 19 @ 5:32 pm
