Is there an opportunity to add a dB level for analyzing songs within VDJ? It appears from my experience that there are different results returned based on what the overall setting in options for dB. If you do not remember changing this setting each time you are getting analysis based on different settings and it is not good. Having this setting separate allows for a more consistent return of results and when changing dB settings for output will be much better. Thx!
geposted Mon 05 Aug 19 @ 5:03 pm
The zeroDb setting does not affect analysis, so if you put it to - 3dB all your songs will be lowered, even the ones scanned earlier.
There is no need to rescan when changing this setting
geposted Mon 05 Aug 19 @ 6:44 pm
I beg to differ based on my experience but okay.
geposted Mon 05 Aug 19 @ 6:56 pm
You've mentioned your experience twice - what is that experience?
Show us some evidence of what you've found.
geposted Mon 05 Aug 19 @ 7:13 pm
