Is it possible to extend the Loop Out count (Effect Slider 4) to 64 or even 128 ?
Now max is 32.
In case of a (for example) 120 BPM track with length set to 1bt, the Loop Out effect runs for 16 sec.
Set to 1/2 bt, it only runs for 8 sec.
The higher the BPM, the shorter the effect runs (simple mathematics ;-)).
The beauty of the Loop Out effect is that it fades out and can be used with an LP or HP Filter (Effect Slider 2) in the same effect. But sometimes 32 is not enough.
Sometimes it just needs to run longer.
Now max is 32.
geposted Thu 08 Aug 19 @ 12:05 am
The problem starts to be, it gets fiddly trying to get the number you want when it's 1-64 in increments of 1.
Perhaps a button that changes the dial to base 2 would do it.
Or you could cheat and have a button to halve the bpm a few times [and adjust the dials] to get more duration out of the fx
geposted Fri 16 Aug 19 @ 3:12 pm
