Topic: CPU On Screen Visual Usage
For some reason I no longer get a visual indication of the CPU usage as one does with the Volume along the top section of the skin. Is It something I've done or has the data that is sent to indicate the CPU usage been modified. This phenomenon happens on both my laptops but currently the program 'Virtual DJ 8 runs fine. Strange. The Controllers I use are Denon MC 6000 MkII & MC 7000 depending on the type of gig.
geposted Mon 12 Aug 19 @ 12:36 pm
NicotuxHome userMember since 2014
Default is now set to Audio for some reason
You can set it to System again in settings -> cpumeter
geposted Mon 12 Aug 19 @ 12:53 pm
Many thanks for your info, however, not had any luck in finding what you recommended on laptop. will keep looking, to attempt a possible solution.
geposted Mon 12 Aug 19 @ 1:32 pm
vdj settings cpumeter
geposted Mon 12 Aug 19 @ 1:51 pm
Many Thanks. Issue Sorted. Kind Regards
geposted Mon 12 Aug 19 @ 2:47 pm
