Me, neither. I clicked on your profile and photos and there is no photo.
geposted Sun 18 Aug 19 @ 7:37 pm
It's no good clicking on my profile if you uploaded the picture to your profile...
geposted Sun 18 Aug 19 @ 7:51 pm
I was replying to OP. Why would I expect your profile to have his pictures?
geposted Sun 18 Aug 19 @ 8:44 pm
Sorry about all this guys. Is it possible to send an email with the pics to anyone.
geposted Sun 18 Aug 19 @ 9:09 pm
Sorry Phil. I thought you were Ben.
geposted Mon 19 Aug 19 @ 11:45 am
Hi Guys
Here is the speakers i am using
https://www.amazon.co.uk/Brooke-INH-PA15-Speakers-Digital-Amplifiers/dp/B007XFXDE0
geposted Mon 19 Aug 19 @ 1:07 pm
Jesus how hard is it to get a detailed picture of the rear panel.
The amazon listing says 15" but the rear panel is from a 12"
Take a photo and host it at tinypic or something then add a link here.
geposted Mon 19 Aug 19 @ 1:16 pm
<a href="http://tinypic.com?ref=9fsjrc" target="_blank"><img src="http://i64.tinypic.com/9fsjrc.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
geposted Mon 19 Aug 19 @ 2:33 pm
geposted Mon 19 Aug 19 @ 2:46 pm
Cool, finally [I wasn't meaning to have a go at you], manufactures that don't supply high res photos of the input panel... well I'll stop there before I start ranting.
Right you have combo ports for input [takes xlr & 1/4" jack] and there's a switch to make the input low impedance [z] for mics or high impedance for line in.
So now I ask have you scored the cable I suggested and have you set the input to LineIn [button pressed in]?
geposted Mon 19 Aug 19 @ 3:20 pm
Nps , button pressed in i was using that same Jack. so from Controller to to speaker Input, removed one RCA( whisper sound , then swapped to the other RCA to make sure then no sound.)
geposted Mon 19 Aug 19 @ 3:31 pm
Is it whisper quite, or is it just treble you're getting?
Really tricky to diagnose from distance, you might have blown the bass driver, without a multimeter it's tough to check.
geposted Mon 19 Aug 19 @ 3:52 pm
Its whisper quite, I am completely lost. it was working before and then all of a sudden nothing.
geposted Mon 19 Aug 19 @ 3:55 pm
Well I'm almost out of ideas, do you have a hifi or mini speaker you could plug your MT into just to prove that it's not that at fault? Do you have another wire you can try with to check it's not the wire.
geposted Mon 19 Aug 19 @ 4:09 pm
Plug a mic into each speaker to make sure they're working properly. Obviously change the position of the switch when you do...
geposted Mon 19 Aug 19 @ 4:27 pm
Hi Mate done that. I'm going mental lol
geposted Mon 19 Aug 19 @ 4:37 pm
....and what was the result? Do the speakers work properly or not?
If the output from the controller is really quiet when you have the 'line' button pressed in, what happens to the volume when you switch it to 'mic'? N.B. TURN THE LEVELS DOWN WHEN YOU TRY!!!
geposted Mon 19 Aug 19 @ 4:41 pm
Yea the speakers work perfect. Could it be the out out board on the controller
geposted Mon 19 Aug 19 @ 4:44 pm
Are you getting a signal to the headphone socket on the Mixtrack? Is the output volume of the Mixtrack turned up? Is the volume of the speakers turned up?
Are you using the default audio config for the controller in VDJ (i.e. a box pops up when the Mixtrack is plugged in, asking if you want to use the Mixtrack audio)?
geposted Mon 19 Aug 19 @ 4:51 pm
Speakers tuned up. Also master turned up. Default audio mixtrack. In config as Numark sound card
geposted Mon 19 Aug 19 @ 5:26 pm
