Hello,
I was wondering if there was any way to display the album cover from the ID3 tag when an audio file is playing.
geposted Thu 22 Aug 19 @ 11:58 am
Effect "'Cover" is here for that. Can be selected both as Audio only source or as Overlay
Some video skins already show it
displays album cover from the ID3 tag if any or attached image if any
geposted Thu 22 Aug 19 @ 1:02 pm
Thank you,
I was hoping that there was something where I can specify the size and maybe put a moving background
geposted Thu 22 Aug 19 @ 3:25 pm
Ah, so when you say "display", you mean on a secondary screen (the video output), not just on the decks?
geposted Thu 22 Aug 19 @ 4:27 pm
yes, I have a secondary display where it displays the video and karaoke, I wanted to do something nice for the audio files.
geposted Thu 22 Aug 19 @ 4:40 pm
I use milkdrop , shader or telly
geposted Fri 23 Aug 19 @ 5:25 am
You can specify both size and position in cover effect parameters gui
geposted Fri 23 Aug 19 @ 5:55 am
For audio only files?
Yes, there are a few options including cover art:
geposted Fri 23 Aug 19 @ 12:43 pm
