i tried to link the shader to the apc 80 and put selected shaders on single buttons but for some reason its not working ,. get_effect_string "shader" 2 "Echo"
now that we have custom pages its even more confusing. maybe its been a long day..
shader page is groovy and sample is geometry . can we do this for all the pages?
geposted Tue 10 Sep 19 @ 2:23 am
What has "Echo" got to do with it?
doesn't this work
get_effect_string "shader" 2 "geometry"
doesn't this work
geposted Tue 10 Sep 19 @ 9:59 am
haha one of my shaders is called echo
geposted Wed 11 Sep 19 @ 2:04 am
it opens shader but does not select the shader geometry
geposted Wed 11 Sep 19 @ 2:08 am
ok , i still haven't had this work.
lets say the folder is "stuff i like"
i have "Promethean"
and im trying to select that shader only what did i mess up
My action didnt work as i thought . nothing happend.
im lost.
i have "Promethean"
im lost.
geposted Sat 16 Nov 19 @ 8:04 pm
effect_string 'shader' 2 'geometry'
works here, you'll need b5402 or greater.
geposted Sat 16 Nov 19 @ 8:49 pm
that's what i have is 8.4 b5402 .
geposted Mon 18 Nov 19 @ 8:14 pm
Ah right, sorry I've already done this one before, I work with shaders on decks, I'm guessing you're using the AOV? [audioOnlyVisual]
geposted Mon 18 Nov 19 @ 8:28 pm
too funny.
geposted Mon 18 Nov 19 @ 8:30 pm
my question stands are you using shaders on decks? or shaders on deck master as a video fx? or as an audioOnlyVisualisation?
where matters.
where matters.
geposted Mon 18 Nov 19 @ 9:16 pm
im trying to use it on master decks . i just wanted to have different shaders linked to buttons on my apc 120 that has 120 buttons. so its just push a favorite shader and it plays as i like . I just let it play in the back ground as im doing my thing .
geposted Mon 18 Nov 19 @ 10:57 pm
I'm guessing you're using the AOV slot then
effect_string "audioonlyvisualisation" 2 "geometry"
with that may buttons to play with you could do so much more video than just pick a shader
This was just 8 buttons and the videoCrossfader was automated with zVideo padpage
geposted Mon 18 Nov 19 @ 11:34 pm
so great. You have your head wrapped around this Loco that's is what the issue was.. freaking awesome..
one thing i did notice i can put in anything with a - in it like rainbow-swirl
geposted Tue 19 Nov 19 @ 7:21 pm
https://virtualdj.com/forums/223743/General_Discussion/Script_School.html?page=3
for all shader scripts
geposted Tue 19 Nov 19 @ 8:03 pm
Nice resource, good job.
You'd probably want to edit link to use https though, as if you are logged in and go to that link, the security cookies are sent in clear text (the cookies doesn't seem to require to be sent secure, which is something atomix might want to look into).
Update: I have reported this to atomix as a security issue.
geposted Thu 28 Nov 19 @ 1:19 pm
