Take a look at the Auto Sync Controls in the User Manual. It sounds like you have at least one of them enabled and you want to disable it (especially Auto Match BPM and Auto Sync on Play).
geposted Fri 25 Oct 24 @ 12:44 pm
Thanks for the suggestions. I checked and none of those are enabled… I think I’m just going to throw in the towel lol
geposted Fri 25 Oct 24 @ 10:23 pm
smart play, auto bpm, smart cue, beat_lock (scratch panel)
also possible you have a script, but not likely as you'd know you have set it.
geposted Fri 25 Oct 24 @ 10:32 pm
If all else fails, backup your settings.xml restart VirtualDJ to see if the problem persists.
geposted Fri 25 Oct 24 @ 11:30 pm
Backup your settings.xml, DELETE (or rename) the original, then restart VirtualDJ :-)
geposted Sat 26 Oct 24 @ 9:22 am
Finally got it fixed. Quantize was activated
Thank you for everyone's help
Greatly appreciated!
geposted Sun 27 Oct 24 @ 4:07 am
