on load no global variable exist
element with visibility set to "get_var '$myvar' " were previously not showing
now since b5269 and in 5281
these elements will show
the opposite
element with visibility set to "not get_var '$myvar' " were previously showing
these elements won't show anymore
if the variable exists hopefully everything is still the same as needed
it look like the get_var verb change its working mode
Many skins now initially show wrongly and buttons / elements / textzone have to use a function affecting the variable in a way to reflect actual real status
how to update such thing ?
the opposite
geposted Mon 16 Sep 19 @ 5:32 pm
Not only get_var was altered, in b5281
affect the value of a slider to a variable does not seems to work anymore the same way
i.e. action="set '$myvar'" was working fine now does not
this affect some skins, some pads, and other scripts
i.e. in pad : pressure="set '$myvar'" does set $myvar to 1 and slider is fixed to 100%
whenever pad_pressure_switch is set to on or off
was previously affecting the value of the slider to the variable and the slider was updated
geposted Tue 17 Sep 19 @ 5:06 am
Tried on custom button and custom slider, but behaviour still seems the same.
Which skin are you seeing this problem with?
geposted Thu 19 Sep 19 @ 1:03 pm
I tried on custom button and custom slider, behaviour still seems have change
Which skin ? mine ^^ default skin with extent working for years,
Which pad page ? Mine and some Locodog's ones
the best way to figureout what went wrong :
custom slider : set testvar
was working well, slider was following variable value
now variable is affected as wanted and slider is stuck to 100%
geposted Thu 19 Sep 19 @ 2:22 pm
Problem with set found, will be fixed soon.
geposted Thu 19 Sep 19 @ 2:38 pm
thanks !!
geposted Thu 19 Sep 19 @ 2:43 pm
I did not find a difference in behavior with get_var though
yes there is, look like it is related
when tested variable does not already exist yet get_var actually does not return 0 anymore but not 1 and no text
i.e. local variable used for visibility in a skin with a toggle button
it looks to me like - maybe- it returns a pointer to null / empty string and would maybe return 'nan' or other string instead of the old 0
this one is not critical and force to cleaner script
worked around all of these by a simple comparison with the value it would take
geposted Thu 19 Sep 19 @ 3:01 pm
still present in VDJ2020 b5308 :(
geposted Tue 24 Sep 19 @ 1:42 am
more info about set and get_var problem - with b5803 - b5281 was acting differently
for a custom slider :
"set testvar" goes on not working anymore, slider visual does not get updated
"set testvar && get_var testvar" fixes it in 32bit version
but this does not work with 64bit version
"set testvar & param_cast" - or any other "& param_equal" like - will fix it for 64bit version
but this do not work with b5308 32bit version
mixed version
"set testvar && get_var testvar && param_cast float"
seems to work in both b5803 32bits & 64bit versions for now
mixed version
geposted Sat 28 Sep 19 @ 2:47 am
Thanks, fixed in b5350
it's somehow working back again
There is still an issue with mouse roller which sets the variable to +/-0.03125 instead of acting relative as for any slider
geposted Wed 16 Oct 19 @ 7:26 am
Ah yes will fix relative values too
geposted Wed 16 Oct 19 @ 8:11 am
Fine, with the fix "set not receiving relative values" now set receives the relative value
result can be 0..100% in absolute
but still not stay in range 0%..100% when relative
geposted Wed 06 Nov 19 @ 12:30 pm
What script did you use exactly?
geposted Wed 06 Nov 19 @ 2:27 pm
