I am using the four deck Block Skin. The Wave Form on deck three goes away when I load deck four when deck 1, 2 and 3 are loaded. The track on deck 3 plays fine and everything else seems to work. I checked my wave form settings to no avail. Why is this happening?
geposted Fri 20 Sep 19 @ 7:32 pm
Which waveform type are you using ?
geposted Fri 20 Sep 19 @ 8:20 pm
Automatic. Other settings: per deck, Show grid lines = no, centered and Skin play head shadow = yes. Happens on 64 bit and 32 bit versions...
geposted Fri 20 Sep 19 @ 8:49 pm
There is no Automatic.
Was referring to the Waveform type from the skin menu
In case you the "Rhythm Left/Right", you will get the waveform of the Left deck, the Right Deck and the Selected, so maximum 3 waves.
If you want to see all 4, then select one of the "All Decks" types
geposted Sat 21 Sep 19 @ 10:12 am
That did it! I really like this skin. I have been using the default. This skin however is nicer to look at. I also like the fact that I can show/hide many features that the default deck always shows.
Thanks...
Thanks...
geposted Sat 21 Sep 19 @ 1:45 pm
