I think a few people use it for advanced sync when doing routines, so it would be good if it was still available on the skin even for loaded decks
geposted Mon 23 Sep 19 @ 7:41 am
Custom button :-)
geposted Mon 23 Sep 19 @ 7:50 am
groovindj wrote :
Custom button :-)
Yes, that will work :)
geposted Mon 23 Sep 19 @ 8:13 am
I just noticed the clone buttons are there (in the scratch tab) on the "essentials" skin. It must be that they're not essential for pro's. :-)
geposted Mon 23 Sep 19 @ 10:08 am
So it is!
I now you were kidding
But it may be fair enough... If you are a pro you'll probably have these kind of things mapped out on your gear, so you don't need it on the skin...
geposted Mon 23 Sep 19 @ 10:35 am
Actually now that most of the graphics are not bitmap, it's quite easy to take the code from the Essentials skin and paste it into one of the others. You don't have to worry about pasting the image from one PNG to another, placing it and entering co-ordinates.
geposted Mon 23 Sep 19 @ 10:40 am
