Good day for all!!!
I was testing the newest VDJ 2020 performance. I works very well, but I have noticed that the quality of video is much worse than previous versions. The VDJ 8.2.3523 version I think has the best video quality, and the 2018 versions had little less video quality (spetially with the SD videos), but works very well. But the 2020 (5308) version, I have noticed 2 details:
1) With the SD videos (720x480 / 720x576 / 640x480), I watch a bit more pixelage than normal (I have my SD videos extract from DVD, or MPEG2 -vob- or MP4 h264 best quality posible renders).
2) With the HD videos (up to 1080), I watch a lot of motion blur.
I test the version with my laptop (i7 4510-U, Intel 4400 HD + Radeon R270M, 12 Gb Ram DDR3) and with my desktop PC (i7 4790k, nVidia RTX 2060, 16GB Ram DDR3), and i have the same problem. I set all the video quality options to the top, and the problem stays there.
If some of you have watched the same problem, or if you don't have (or percieve) any problem with the video quality, please tell me. At this moment, I'm continue using a 2018 version for give a nice quality video sessions. I use a DDJ-SX3, and an old VDJ 8 version doesn't work with it.
PD: If some of you made a better (or corrected) DDJ-SX3 mapper than VDJ default, please upload (if is posible) to the downloads section.
geposted Thu 26 Sep 19 @ 9:21 am
Is this with the 64bit version of VDJ ? If not, can you please try with it ?
Download it here https://virtualdj.com/download/
geposted Thu 26 Sep 19 @ 4:11 pm
Correct. I test both versions (32 & 64), and the problem is with 64 bits version, with the 32 bits version the video quality is good.
geposted Sun 29 Sep 19 @ 6:48 am
Yes. I have the problem with the 64 bits version.
geposted Sun 29 Sep 19 @ 6:51 am
Yes.. I have just downloaded the 64bit version. I have replicated the video settings for the NVidia panel (both 32bit and 64bit versions of Virtual DJ) -- I have added some attachments so you can see the issue... The settings in VirtualDJ for Video are for both versions to use the NVidia card.
32BIT SMOOTH GRAPHICS ON THE ALBUM COVERS
64BIT JAGGED GRAPHICS ALBUM COVERS
NVIDIA SETTINGS FOR BOTH 32BIT and 64BIT
geposted Sun 29 Sep 19 @ 7:13 am
Hello. I have the same problem with the 64bit version. Has a very low quality video compared to 8.3
Anyone with a solution please advise
geposted Tue 08 Oct 19 @ 4:04 pm
Screen grabs from a Standard Definition Music Video (same file in both 32bit and 64bit versions) - look at the diagonals (chin area of faces etc...), the 64bit version appears to be worse... any ideas why? Could it be a sharpening option???
64BIT running a standard definition music video
32BIT running the same standard definition music video
geposted Wed 09 Oct 19 @ 11:57 am
what resolution is this video exactly?
geposted Wed 09 Oct 19 @ 12:13 pm
My system:
Lenovo G50-70
Core I5 processor
Windows 10
6 GB Ram
64 bit OS
X64 based processor
VDJ version 8.4.5308.0
My problems:
Tag Editor- does not display field names or data
Cue button displays as _ue
Sync button displays as_nc
This occurs in the Pro Screen and Performance Screen
Lenovo G50-70
Core I5 processor
Windows 10
6 GB Ram
64 bit OS
X64 based processor
My problems:
geposted Wed 09 Oct 19 @ 6:07 pm
Any update about this possible issue? Using VDJ 2020 since a few days I can't find major differences in my PC monitor, but I'm afraid working with the projector and a big screen would be noticeable. Cheers
geposted Thu 10 Oct 19 @ 9:29 pm
At this moment, I recommend to work with any previous version you have in your computer, or, if you wanna work with the 2020, use the 32 bits version: in my case, I work with a 2018 version. I made some tests with both versions, and is the best option I could give. The 64 bits version has many bugs right now.
If you have another computer in your house, o a virtual machine installed in your PC/MAC, or in your current system (preventing any problem you could have), try to make all the test you can with both versions (32 and 64 bits) to look any fail that isn't present in previous versions, and write a post with the problem to give the news to all of us for to stay informed.
geposted Fri 11 Oct 19 @ 6:02 am
Not necessarily related to smoothness issue, but you should notice in the above images (video display area) that in the 32 bit version the colors are washed out while in the 64 bit version the colors are more vibrant. This appears to be due to 32 bit version using reduced color range for YUV decoding which is not good either. 64 bit version appears to be using the full color range for YUV decoding.
Here's an image that shows the difference more clearly. In the reduced color range you can see gray when it should be black.
geposted Fri 11 Oct 19 @ 3:49 pm
My virtual dj 2020 doesn't show videos why
geposted Sun 03 Nov 19 @ 9:34 am
Experiencing the same. The depth has improves (ref. Don Moir, it considers the full range), but the interpolation/resampling seem to have changed from bicubic to bilinear?
geposted Sun 03 Nov 19 @ 9:28 pm
Can you also test again with the "videoMicroFrames" option sets to "Never", not to impact the screenshot?
geposted Mon 04 Nov 19 @ 9:28 pm
Same issue
geposted Tue 03 Dec 19 @ 5:29 pm
If you mean in the browser you have probably set it to only show audio. There is a dot left side of browser click that and enable video.
geposted Tue 03 Dec 19 @ 5:41 pm
Glad I read this post as I have noticed the difference in video quality, thought it was a setting on my laptop.
Video output looks poor on the big screen, with new version.
geposted Thu 23 Jan 20 @ 8:26 pm
Are you using the latest update?
The problem with the windows 64-bit version was fixed in the current public release.
geposted Thu 23 Jan 20 @ 8:32 pm
I feel I'm still having problems with the video in Virtual DJ 2020. Can someone tell me the best settings? I'm using an alienware 17 R4 i7 6700HQ 16 gig memory 500gig Samsung M.2 860 EVO SSD Nvidia GTX 1070. More than enough to DJ with but since upgrading to 2020 the video is horrible. even my low quality videos were better on vdj 8.
geposted Sat 07 Mar 20 @ 5:53 pm
