Sorry if this was already answered before but I've looked in the forum and couldn't find an answer to this question.
Is there a way to map a button action to load a particular skin? I would like to be able to use say, the Pioneer touch skin and when the other dj comes to play, he can click one button and switch to say, the default skin without having to go to the menu>interface>load skin.
Sincere thanks for all the skin gurus out there, your work is truly appreciated!!!!
geposted Fri 27 Sep 19 @ 12:26 pm
          skin_load 'NameOfSkin'
Also:
skin_load 'NameOfSkin:VariationOfSkin'
    Also:
geposted Fri 27 Sep 19 @ 12:28 pm
          Thank you Phantom, can you give me an example, I tried
<button class="padsmall_orange" action="skin_load 'normal' ">
Which never worked. Sorry, I'm new at this :(
geposted Fri 27 Sep 19 @ 7:07 pm
The action to use is load_skin
Replace 'normal' with name of the skin variant (click the [+] in the skin setting for the skin you are using to see what variants it contains). And put a colon in front of it.
As example for the VirtualDJ 2020 default layouts :
action="load_skin ':Pro' "
Or if you want to switch between totally different installed skins, put the name of the skin before the colon
load_skin 'Old:2 Decks' (but probably not what you were looking for I guess, rather change variation of one skin)
geposted Fri 27 Sep 19 @ 7:30 pm
          It worked! You guys are truly the best! Cheers!!!!
    geposted Fri 27 Sep 19 @ 7:51 pm
