Hello, i'm trying to configure a Smartpad with virtual Dj creating his definition, i'm okay until i have to mess with the leds , for example:
in miditrace if i wanna to turn on a red led on the button 1 i only need to write "90 00 7F 00, turning it off it's 80 00 7f(any value) 00
My problem is in virtual, with " <led note="0x00" value="0x7f" zero="" default="sampler_pad 1" name="LEDR_SAMPLER_1" />" it's turn on alright, but dosn't turn off (when using blink, or whatever command i just use <map value="LEDR_SAMPLER_2" action="sampler_pad 2 ? on : nothing (or off, etc)" />)
How i can do to fix this? i'm trying diferents metods and right now i'm using : <sysex value="80000000" zero="" name="LEDOFF_SAMPLER_1" /> and a mapping to help me with , but i don't feel right.
Greetings from Argentina!
Kevin.
Kevin.
geposted Sat 28 Sep 19 @ 2:27 am
<button note="0x00" name="R_SAMPLER_1" deck="1" channel="0" />
<led note="0x00" default="R_SAMPLER_1" name="LED_R_SAMPLER_1" deck="1" channel="0" />
geposted Sat 28 Sep 19 @ 4:17 pm
thanks for reply PhantomDeejay
I tried this but it's the same, the led stays on , even with a off command on vdj
Thanks anyway! and have a good evening
geposted Sat 28 Sep 19 @ 7:44 pm
Do you have a file with the MIDI specs of the device?
geposted Sat 28 Sep 19 @ 8:28 pm
Hi, any update on this one?
I just bought the MidiPlus Smartpad.
Would be nice to be able to control the LEDs.
geposted Sat 23 May 20 @ 9:15 am
I just started this topic https://www.virtualdj.com/forums/236471/VirtualDJ_Technical_Support/Midiplus_SmartPad.html
Can't seem to switch off the leds, colors work.
i got the pocket midi program to test the pad, and then it does work the leds turn on and off.
geposted Thu 30 Jul 20 @ 1:23 pm
In my topic, i posted the mapping to the smartPAD, it has to work with a 6 digit sysex command otherwise the leds do not turn off
geposted Thu 10 Jun 21 @ 7:31 am
You can try for the led...
and replace the NN with the Note/value you get for its button (e.g. 00, 01,etc)
Then in mapping , you can use .. actions like..
color 'red'
play ? color 'green' : off
loop ? blink 500ms ? color 'blue' : off : color 'magenta'
<enum>
<color note="0xNN" values="table" name="LED_PAD1" channel="0" table="0x7F=red,0x60=green,0x50=blue,0x40=magenta,0x30=cyan,0x20=yellow,0x10=white"/>
<sysex default="yes" value="80NN00" />
</enum>
color 'red'
geposted Tue 15 Jun 21 @ 1:13 pm
