Topic: dissapearing virtual folders, and contents
i was dragging my virtual folders around trying to organise them
but i found that after i dragged a bunch of them into a master folder
i looked inside and the virtual folders were nowhere to be found
i perhaps i didnt drag it properly or something, but i dont know where the folders are now....
pretty upset because i seem to have lost some vital data
any ideas why this is? i wish therre was a 'file operations/move' option for these, because dragging them seems dodgy
geposted Sun 29 Sep 19 @ 9:06 pm
Go down your list and look into all that have "+". Your tracks might be hiding in an adjacent folder to the one you were dragging the tracks to. Good luck.
Go to "Documents\VirtualDJ\folders" folder and do a search there.
Also if you use external drives go to G:\VirtualDJ\folders and repeat the search...
If both searches fail then most likely you dragged the folders into a physical music folder. If their name is somehow unique you can do a search on your music library to locate where the files have gone.
