Forum: VirtualDJ Skins
Topic: Icons VDJ 2020 as png
Is there a way to get the default Iconset of VDJ 2020 as a PNG-File?
geposted Thu 10 Oct 19 @ 5:10 am
geposted Thu 10 Oct 19 @ 6:58 am
geposted Thu 10 Oct 19 @ 8:19 am
No, you've got it the wrong way around. Normal icons are white, because the background is usually dark. Daylight icons are black.
geposted Thu 10 Oct 19 @ 8:35 am
But those Icons are not in the Default 2020 Skin, some of them are in the Daylight Skin. You can check the Virtual Folder Icon (Red Icon) so you can see what i mean.
geposted Thu 10 Oct 19 @ 12:21 pm
Yes they are in the default 2020 skin (at least on my system they are). And yes, some of them are the same in the daylight skin.
The daylight set only changes the icons that need to be changed. Others are exactly the same as the default ones.
geposted Thu 10 Oct 19 @ 12:30 pm
I now it, and in the default Skin there is a png File for the Daylight Skin and this file has the same Icons as in your Link.
But i need the Icons of the default Skin, not for the daylight skin. ;-)
geposted Fri 11 Oct 19 @ 6:57 am
I already gave you the link!
geposted Fri 11 Oct 19 @ 7:14 am
