Forum: VirtualDJ Skins
Topic: Release FX
There is a Funtion Release FX .
But as Script only a Slider Funktion avaible.
How can I make a Slot in My Skin for Select a Release FX and aktivate a Release FX ?
And the same Command for a Controller Button or Slider ;-)
Greetings Dani
geposted Thu 10 Oct 19 @ 8:02 am
NicotuxHome userMember since 2014
These are only results of trial/error - nothing official though
everything may work or not depending on builds and many may be wrong/missing
tested with 8.3 b4752 and seems to already work
effect_select releasefx : Show effect selector for Release channel with potential access to Video Effect Selector /? seems to affect effect slot #7
effect_show_gui releasefx : Show/Hide gui for the fx in release slot ; can be used as a query
get_effect_name 'release' : name of current release effect in slot 1
get_effect_title 'release' : name of current release effect as '<Name> - Release'
effect_active releasefx : activate relase fx ; can be used as a query
effect_slider releasefx n v : modify the nth slider of the release fx; v can be relative ; can be used as a query
effect_slider_reset releasefx n : reset the nth slider of the release fx
effect_has_slider releasefx n : Query whenever the nth slider exist
effect_button releasefx n : modify the nth button of the release fx; v can be set on or off, 0 or 1, true or false ; can be used as a query
effect_has_button releasefx n : Query whenever the nth button exist
hope it'll help
geposted Thu 10 Oct 19 @ 4:40 pm
No thats nothing work .
No one from this Scriptcommands are work.
Look under Plugins in the Mapper , but there only the Commands effect_releaseslider and effect_releaseslider_active.
But I need the Command to select the releasefx and activate it... But the is nothing.
geposted Sat 12 Oct 19 @ 7:30 am
releasefx is a slot so
effect_select 'releasefx'
effect_active 'releasefx'
geposted Sat 12 Oct 19 @ 10:05 am
So there is (still?) no option to set a release effect and have it automatically trigger in some way or form, when a "regular" effects is released to create like an automatic effect tail?
geposted Sat 12 Oct 19 @ 10:19 am
Not 100% releaseFX is one that I don't really use, a rsi could do it for sure.
geposted Sat 12 Oct 19 @ 3:06 pm
I use them for a while... sure they all work !!
4 pads extracted from one daily working pad:
<page name="MicSamplerReleaseColor FX">
<pad9 name="Deck `get_deck` \nRelease \n `get_effect_name releasefx & param_ucfirst`" color="color green" autodim="false">
get_effect_name releasefx & param_equal '' ? effect_select releasefx : effect_active releasefx
</pad9>
<pad10 color="color_mix pink red `effect_slider releasefx 1`" name="▼ `get_effect_slider_label_full releasefx 1`" autodim="false" pressure="effect_slider releasefx 1">
holding ? effect_slider releasefx 1 0% : effect_slider releasefx 1 -2%
</pad10>
<pad11 name="`get_effect_slider_text 'releasefx' 1` ▲" color="color_mix pink red `effect_slider releasefx 1`" autodim="false" pressure="effect_slider releasefx 2">
holding ? effect_slider_reset releasefx 1 : effect_slider releasefx 1 +2%
</pad11>
<pad12 name="`get_text 'RELEASE\nFX GUI'`" color="color violet" autodim="false">
</pad12>
<pad13 name="`get_text 'RELEASE FX\nSELECT'`" color="color blue" autodim="false">
</pad13>
<pad14 name=" `get_effect_button_name releasefx 1`\n`get_effect_slider_name releasefx 1`" color="get_effect_button_name releasefx 1 & param_equal '' ? color lightgray : color orange" autodim="false" pressure="effect_slider releasefx 1">
effect_button releasefx 1
</pad14>
<pad15 name=" `get_effect_button_name releasefx 2`\n`get_effect_slider_name releasefx 2`" color="get_effect_button_name releasefx 2 & param_equal '' ? color lightgray : color orange" autodim="false" pressure="effect_slider releasefx 2">
effect_button releasefx 2
</pad15>
<pad16 name=" `get_effect_button_name releasefx 3`\n`get_effect_slider_name releasefx 3`" color="get_effect_button_name releasefx 3 & param_equal '' ? color lightgray : color orange" autodim="false" pressure="effect_slider releasefx 3">
effect_button releasefx 3
</pad16>
some customs buttons:
I found it to be a good place for such a plugin...... thanks to locodog :
effect_select 'releasefx' 'builder'
effect_select 'releasefx' 'echo'
Q : "So there is (still?) no option to set a release effect and have it automatically trigger in some way or form"
A: Yes there is , as Locodog and I said its like a slot, maybe 7th, use 'releasefx' as slot parameter instead of a slot number in any effect related command
same apply to 'sampler' 'mic' 'releasefx' 'colorfx' ...
geposted Sat 12 Oct 19 @ 4:58 pm
