Topic: Automatic Pitch
I am using a Denon HC4500 controller with Virtual DJ 2020 and the pitch is automatically changing so I have to move the pitch back into the middle on every track. I have been into the options and changed the BPM setting to No in settings under Audio and reset pitch after every track but still experiencing issues. Can anyone help please. Thanks John
geposted Sat 12 Oct 19 @ 11:30 am
Deck options menu next CUE on the left deck next to SYNC on the right deck (PRO skin). Switch off all the auto stuff. 😉
geposted Sat 12 Oct 19 @ 11:51 am
newme41PRO InfinityMember since 2008
Hello
There are some probleme with auto pitch desable or not de auto Pitch the key stay's always the same
Best regards
geposted Thu 09 Sep 21 @ 3:00 pm
The easyest way I found was in the software go to options and select automation and it is all there hope it helps.
geposted Thu 09 Sep 21 @ 5:49 pm
i have disabled auto pitch but nothing. everytime i load a new song is changing...
geposted Tue 26 Apr 22 @ 11:17 am
