Topic: Skin saving issue
grennoPRO InfinityMember since 2012
There's an issue when switching between skin layouts
If I select Performance layout and set up the skin how I use it (FX x1, Pads(Favourite) etc) and I close/reopen VDJ, it remembers my preference which is great.
However if I go to the Pro layout and then go back to Performance, it reverts back to the default setup with the pads etc.
I find myself going between the skins quite often depending on gigs/workflow so it would be very useful if VDJ could remember how I have each layout customized when switching beween them
geposted Mon 14 Oct 19 @ 11:38 am
