I use automix a lot. I like the new autoKey feature but when I am using automix the two songs mix together then when the mix is finished there is a sudden key change, which sounds very noticeable.
I think it could be fixed by:
1. Allowing disable of AutoKey when automix only; or
2. Changing the key slowly during the transition between the two tracks
Let me know if I have missed something
geposted Mon 14 Oct 19 @ 7:57 pm
