When i make video window full screen on my monitor without Blur Black Bars..
and here WITH Blur Black Bars...
What I'm seeing is more noticeable while video is playing.
I've turned off video microframe in-case it was this affecting.
I dont have time to check this while connected to video out and don't have time to start taking screenshots at gigs :/
[edit] also happening in 32bit.
geposted Thu 17 Oct 19 @ 4:01 pm
You might need to explain what you see wrong since it looks as it was intended for me
geposted Thu 17 Oct 19 @ 4:16 pm
Its difficult to get a good screenshot of before and after but if you compare the two images, the writing on the drum kit is more blurred. but ultimately motion appears more pixelated (impossible to screenshot)
its as if the Bars plugin is reducing the image resolution..
geposted Thu 17 Oct 19 @ 4:18 pm
I mmostly don't use blackbars but it true :
some visible examples using a gif with which it really noticeable :
without blurblackbars : https://imgdb.net/7073
With blurblackbars : https://imgdb.net/7074
geposted Thu 17 Oct 19 @ 8:00 pm
