Hi guys
I remember last year being recommended an XML editor but unfortunately the computer it was installed on died hard drive failure . I have moved over to SSD now .
I can’t remember the name of the one you guys recommended but it was amazing could you guys recommend some decent XML editors free versions . As would like to make some adjustments to the new pro layout thank you .
geposted Fri 18 Oct 19 @ 2:41 am
Personally I don't use an explicit XML editor.
Instead I use Notepad++ which has a lot nice features for XML files
geposted Fri 18 Oct 19 @ 7:30 am
I use pspad and it's good.
geposted Fri 18 Oct 19 @ 8:24 am
+1 for recommending Notepad++
Working for hours on code can be a nightmare but in np++ you can change the colours to something darker so it’s lees strain on the eyes ( unlike windows notepad which is stuck with a white screen)
geposted Fri 18 Oct 19 @ 6:34 pm
Third vote for Notepad++
I find it invaluable for skin work.
geposted Fri 18 Oct 19 @ 7:42 pm
Thanks guys . Notepad++ what’s the one I was using before .
Regards Matthew
Regards Matthew
geposted Sat 19 Oct 19 @ 5:54 pm
