Hi all - I'm looking to do a Manual Sweep effect in my sets. I know there used to be a downloadable one in the effects section here but all I can find is the Manual Sweep. When I try to download it says I need to be VDJ to dload. The problem is that it doesn't show up under the available effects in VJD when I search for it. I see every other effect EXCEPT sweep.... am I missing something? I've signed out and back in, checked network and made sure I'm running the latest and greatest w/ v. 2020. Any help would be appreciated!
geposted Wed 23 Oct 19 @ 1:51 am
Try the native "noise" fx
it sounds like you are using 2020x64, the sweep fx is only available for x86
geposted Wed 23 Oct 19 @ 9:10 am
Will do thanks for the input!
geposted Thu 24 Oct 19 @ 9:51 pm
