Hi, is there a script command to get a list of "Video Skins" and select one (as for effects or transitions)?
geposted Mon 28 Oct 19 @ 10:52 am
you can query the current one
setting 'videoSkin' & param cast text
setting 'karaokevideoSkin' & param cast text
you can set the one you already know and layout if any
setting 'videoSkin' 'for Live:live'
setting 'karaokevideoSkin' 'for Karaoke:karaoke'
but it seems there is no list or selection popup
or load_skin and switch_skin_variation verbs as for main skin
settings 'interface'
will open the setting page to select main skin & video skin
geposted Mon 28 Oct 19 @ 11:21 am
Nicotux, I already know those commands and I currently use them to activate some video skins using custom buttons; but the custom buttons are still limited in number; a selection window would be useful, just like with transitions or effects.
Thanks anyway for your interest.
geposted Mon 28 Oct 19 @ 11:40 am
Ho, I'm interessed in this either ^^
I currently use a pad and pad menu with manual list of skins & layouts for this purpose
but it's still a workaround
the other hand, my custom skin needs some pads to control dynamic OSD on display
maybe it can help : extracted from my pad menu :
Default =[setting 'videoSkin' 'for Live:live']
Arrows =[setting 'videoSkin' 'Just Videos/:Just Arrows']
geposted Mon 28 Oct 19 @ 1:23 pm
