Hi
Using the sampler, the volume level of the samples regularly resets to almost zero.
When this happens, it affects all the samples in the bank.
It may only be affecting banks that I've created myself, or edited... I haven't noticed the issue with other banks (but I'm mainly working with edited banks)
Any ideas what might be causing this?
geposted Tue 29 Oct 19 @ 3:08 am
Is it random, or after you’ve switched banks? This is one of the “features” of VDJ 8.
geposted Tue 29 Oct 19 @ 12:44 pm
Can confirm there is a problem with sample volume, at least for custom samples. In my case though, the volume increases and seem to be somewhat random or some form of "build up". Did not change bank in between (in this case a ID sample played on top of a mix). VDJ 2020/64-bit/Win10.
Just a guess: maybe the internal byte buffer for the sample is changed instead of keeping the resulting data after applying the sample's gain once, or put differently: the sample's gain is applied several times (in some situations) and depending on its setting (+/- value) the sample increase/decrease volume as a result? This could also explain why some samples are unaffected if the gain is "0" (no change).
geposted Tue 29 Oct 19 @ 1:45 pm
Both... It often happens while working solely within one bank.
I'll set the volume levels, start playing the samples, and sometimes within just seconds, they'll be back to 5% or so.
geposted Tue 29 Oct 19 @ 10:10 pm
Using a controller with touch sensitive pads? That are mapped to control volume of sample by press strength
geposted Wed 30 Oct 19 @ 1:03 am
hmmm that would make sense, but as far as I'm aware my VCI-400 doesn't have touch sensitive pads...
geposted Thu 31 Oct 19 @ 7:16 am
Ah... Not on the VCI-400 but it looks like the Ableton Push which is also connected, might be the source of the problem... Problem solved, for now :-\
Thanks.
geposted Thu 31 Oct 19 @ 8:24 am
