I love effects!
but 3 is not enough. Is there an easy way to use more than 3?
Currently I use the FXBank plugin in which there are 8 banks of 3 effects. You can swap the banks.
Is it possible to make a custom button that controls the FXBank to change the 3 effects?
I can use "effect 'FXBanks' button 1" to load a bank but how to set which bank from the 8?
geposted Sat 09 Nov 19 @ 4:17 am
