I am trying to set the preset with eq10 by script. I am able to turn the effect off and on an step through the presets with button 5 or 6. Button 2 opens the preset menu but I can't find a way to set the preset with script. Maybe effect_command? Can anyone help?
geposted Thu 14 Nov 19 @ 3:56 pm
change preset, query the effect_string against your preset name if true there you are, if false do the same thing again
depends on how many presets you have
it's really just this used many times
effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing :
effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6 & effect_button "EQ10" 6 & param_equal `effect_string "EQ10" 1` "YOUR_PRESET_STRING" ? nothing : effect_button "EQ10" 6
geposted Thu 14 Nov 19 @ 4:43 pm
Thanks! That will work.
geposted Thu 14 Nov 19 @ 4:49 pm
