Forum: Addons
Topic: 32 Samples
Discussion about 32 Samples
This Pad page offers the ability to control up to 32 samples from one side/deck.
Parameter 1 changes Sampler Bank
Parameter 2 changes from Samples 1 to 8, 9 to 16, 17 to 24 and 25 to 32.
geposted Fri 29 Nov 19 @ 1:19 pm
hi, and thanks for the map...but what is ‘4x4x1’ in the map??
Thank you this sounds awesome!!Gonna install
hi, have you this bug in rightdeck 2-4 decks? if i make pad page ‘sampler’ in rightdeck and i have a sampler_bank with more 8 samples i can’t switch to page 9-16, i think virtual dj ‘think’ is already with pad 9-16 because bank have more 8 pad, right?
Works correctly here on both Decks/Sides. I can select any 8-Bank of Samples using the 2nd Parameter of the 32 Samples Page.
Perhaps you need to use pad_page "32 Samples" action or assign the 32 Samples page to both sides Pad modes.
yes i have solved 👍 thanks
