Topic: Previous load
Hi seniors
I want an action for this:
If I change a song of a deck and want to load the one I recently change can I get an action for that
geposted Mon 02 Dec 19 @ 9:46 pm
Nothing like that or
Yes, I use the Back button on my Denon MC7000. A press and hold function. I'm about to add it to my thread.
Undo Load
BACK
holding ? undo_load : browser_folder
Edit: but I will be changing 'browser_folder' to something more suitable.
Thanks
But I want one which will undo till the first track I load.
undo_load
It undo once.
there is nothing it can undo till the first track u load
Yes, it only undo's to the previous track. How many times to you change your mind before playing a song.? Due to the length of time it takes to load a track (which would be 1 undo), rather than skipping through many undo's, it would be better to simply manually load it.
If you want to go back to a track you've previously played, use your history.
The undo load is meant for when you change your mind back at the last minute, and there's not really time to grab the track from the browser. This feature enables you to be able to change your mind and the track, with ease. Without it you wouldn't be able to, it's an essential feature. A continuous UNDO LOAD doesn't really serve it's purpose due to how it would work. They may add to it in the future but I understand why it isn't that way as is.
OK thanks to you all
