Hello,
What do I edit in the pro.xml file to make the waveforms bigger in the Pro layout for 2 decks. I'd like the waveforms window to be a tad taller, if possible (see attached). Thank you for your help.
geposted Sat 04 Jan 20 @ 11:17 pm
You have to resize the waves, also reposition the decks & mixer for the case of wavepos 0, and also shrink down the browser.
Then for 4 decks you have to deal with the swap decks and the 2+2 mixer.
Start with the waves in to below position that will help you get the browser right. after that it should be easy.
geposted Sun 05 Jan 20 @ 11:20 am
Thank you I will check it out.
geposted Tue 07 Jan 20 @ 4:18 pm
