Hello.
I have found an little Error on the Padpage CueLoop.
When I try to delete the 8. Hotcue with Shift , than it not delete the 8. hotcue.
I have look in the PadPage Settings an have found there is the command to delete the 6. Hotcue.
I have correct it by my PadPage.
Want to tell only the other Users and Devlopers from from thi little Error.
Greatings Dani
Greatings Dani
geposted Tue 28 Jan 20 @ 11:53 pm
The default CueLoop Pad page indeed doesnt offer hotcue deletion with SHIFT.
Have a look at the default operation https://virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads.html#cueloop
The Right-click (or SHIFT+Pad from controller) will jump to the saved loop instead of just arming if prior to current position
geposted Thu 30 Jan 20 @ 8:58 am
Here 2 Screenshots . One wenn normal and the second when I drop the Shift on my Controller.
I dont know what You have for a CueLoop Padpage , but I have the only one the is in Virtual DJ to have...
I only would tell You and the others only this Error I found.
By my PadPage is this now ok.
Greatings Dani
Greatings Dani
geposted Thu 30 Jan 20 @ 5:10 pm
The cueloop pad page included with VirtualDJ indeed does not include Delete, so the one you had seems to be one you edited yourself, or downloaded from somewhere.
geposted Thu 30 Jan 20 @ 5:22 pm
Have Downloaded from her , longtime ago , at the first Time since VDJ have Padpages.
My CueLoop have the Shift Delete funktion.
I dont know from which Perso its make this , but its the best CueLoop Page.
ok when yous is good , i think also that the delete optio must hafe this..
My CueLoop is good.
But any PadPage here from download has this Error in it..
Find it self. There 3 Cue n Loop Pads for download here ;-)
Have a Good Evening
My CueLoop is good.
Have a Good Evening
geposted Thu 30 Jan 20 @ 6:58 pm
