Topic: Play Lag on certain tracks.
I haven't paid for it yet and keep running into this same problem. The start on certain songs are lagging because of certain songs that you are trying to mix with. It's usually fine through the first part or so of the song, then changes after a change in a songs BPM. It's fine when you test it with cue, but when it plays it won't start on time. Is this because it is the free version?
geposted Sat 14 Mar 20 @ 1:37 am
You are probably experiencing latency from your audio interface. I assume you're using only a computer - no DJ controller or external equipment?
geposted Sat 14 Mar 20 @ 7:46 am
