Topic: Code Vitural DJ 2020
Hi there
I need an activation code for my new computer.
The Virtual DJ no longer accepts the old code.
Please send a new code to my e-mail
Best regards
geposted Sat 14 Mar 20 @ 9:47 pm
contact support
VirtualDJ doesnt use codes, only your login (account).
Except for a very limited free version that comes with some controllers.
If you have such a free version, the code is both for the one type of controller only, as well as sometimes the code can be for a very old version of the software. Depends on what you mean by "old code" (how old, and what controller)
If the code was for version 7, you will need to get a new license. Either Home Plus (single controller) for home use, or Pro that works with any and all controllers.
See here : https://virtualdj.com/buy/
virtual dj 2020 limited edition code
What about it?
Hi there
Best regards
There is no code in your case (and most others...). VirtualDJ uses your account, and login.
Simply login inside the software, at your new computer... thats it ;-) license activated there
Hi I'm looking for a new code for my g4v controller the old code dosent work
Thankyou
The code that came with that controller was for an old version of the software only (And a limited version)
You need to get a license to use modern version. You can choose between Home Plus (for a single controller, home use), or Pro license (works with any and all controllers)
Can use make it work please
As said already .. If it's a V8 LE or more recent license
Login here with the same account you use to initially register
It will appear in My Account -> My Licenses
As well, using the original account in VDJ will make it recognize license automatically
It will appear in Settings -> Licenses
If you can't access your old e-mail account or it does not exist anymore this won't hurt
Badly if it's older version either install original old version or buy a new one to upgrade :\
I reinstalled my numark pro today to my virtual dj that has now upgraded but it seems I have to have a new licence when I bought my numark pro II I had a full version of Virtual DJ but since then it has upgraded on many occasions and now the licence setup has changed along with my full version of Virtual Dj ? I have a version of serato but would like to continue here . Could I please get some help soon as possible .
Thank you
Mark Thomas
G.I.RECORDS UK
If what Im seeing is true could I also get my New code for my Virtual DJ please ?
You are registered as a free home edition user
So not with a paid license
