Good day team
I use VDJ mostly in 2 deck mode ( performance mode and vertical wave format )so is it possible enlarge the 2 desks and make the library small because I am finding hard to see the writing in the decks and its not cool wearing glasses PLEASE PLEASE
geposted Sun 15 Mar 20 @ 5:51 am
What's the physical size of the screen you're using, and what is the resolution?
geposted Sun 15 Mar 20 @ 9:09 am
You cant enlarge just the decks or any other part of a skin. For that, you will have to either take a look at the Custom available skins (Extensions inside VDJ) and see if any is close to what you want, or create your own.
geposted Sun 15 Mar 20 @ 2:11 pm
Hello all I have no idea how to create my own ( skin ) would be awesome to be able to do that
geposted Sun 22 Mar 20 @ 6:59 am
There's a skin by djdad called Skin Builder, that can be used to create your own skin.
It loads in VDJ just like a normal skin, but allows you to build your own design. A separate program called Skin Builder Extractor then finishes the job.
geposted Sun 22 Mar 20 @ 8:21 am
Thanks will look for it
geposted Mon 23 Mar 20 @ 7:24 am
