The results on the extensions page are cached, so it might take up to 24 hours before an update appears.
    geposted Mon 20 Apr 20 @ 2:02 pm
check this color: #587190
Much much better..Thanks!
geposted Mon 20 Apr 20 @ 2:50 pm
          Hi DennYo Which line in the Skin.xml should I change if I want the Author & Title to scroll.? Thanks for the cool upgrade .!!!
    geposted Mon 20 Apr 20 @ 4:17 pm
What do you mean by "appears"? Available to download, or showing as an update on the button?
Can this delay be improved?
          Showing an update on the button. Uninstall/Install will download the actual latest version.
The cached data is in Documents\VirtualDJ\Cache\Plugins
geposted Mon 20 Apr 20 @ 6:12 pm
          OK so it's not necessary to wait until it says 'update' on the button? I'll give it a try.
    geposted Mon 20 Apr 20 @ 6:53 pm
Denny DennYo wrote :
Version History 3.0.6
-Bugfix - the Custom Buttons on toggle pad and cue area are visible, now
I had noticed the missing Custom Buttons and Dials on Deck 1, and wanted to report it. But now that I see this post, I want to make sure if my graphic below is concerning the same bug. **Updated Note: I just uninstalled and reinstalled the interface and received the latest version 3.0.7 with this fix in place, thank you!
       geposted Mon 20 Apr 20 @ 8:50 pm
          Noticed a bug concerning the 44 Custom Button Bar and Browser is covering Decks 3 and 4, rather than residing under Decks 3 and 4
       geposted Mon 20 Apr 20 @ 8:55 pm
          Version History 3.0.9 - 2020/04/21
-Bugfix - many positions of the Browser Area was wrong
-add - you can now change the Artist/Title Info to scroll text
________________________________________________________________________________
geposted Tue 21 Apr 20 @ 4:38 pm
          love ii. once you work out the no center view this will be my goto....
    geposted Wed 22 Apr 20 @ 3:03 am
What do you mean with work out the ne Center view. The no center view is finish.
geposted Wed 22 Apr 20 @ 6:35 am
          Hello . This is an audio related bug: I think this has to do with the use of  your interface:  While recording a mix with your  interface the audio does a lot of clicks and pops , that when  done with the default skin, audio is perfect. Seems like when buffer is set incorrectly.
    geposted Sat 25 Apr 20 @ 10:47 pm
I need more information about your system. (WIN, MAC?)
On my Win 10 INTEL i7 i doesn't have any problems. I think youre system is to slow for the big Skin XML of my skin.
geposted Mon 27 Apr 20 @ 2:22 pm
My system is OS in a mac book pro with a 16MB and a i7 of 3.5 running really low cpu (less than 30%) I know this because I ran a software to have this checked.
geposted Mon 27 Apr 20 @ 11:54 pm
          Hi Denny-
Could you please someway (like in previous skins : dennyo hd) make the saved loop slots position marker appear on the waveform (like in picture1 or 2)
picture 1 : vdj pro default skin
picture 2 : Dennyo hd skin (older skin)
picture 3 : Dennyo hd 2020 skin
thanks a lot
thanks a lot
       geposted Wed 29 Apr 20 @ 10:36 pm
romeodan wrote :
Hi Denny-
thanks a lot
thanks a lot
I can not reproduce the BUG. I can see the marker for the saved loop on my skin.
Please post a screenshot from the "Variable support page"
Have you someone change in the img.png of my skin? i can't also see the normal CUE markers on your screenshot.
geposted Thu 30 Apr 20 @ 4:38 am
          Hi Denny-
solved it !
uninstalled the skin & installed it again & it worked
thanks a lot !
take care & stay safe
    solved it !
thanks a lot !
geposted Thu 30 Apr 20 @ 12:28 pm
          Is it possible for me to make the Text Fontsize a litle more bigger?
    geposted Fri 01 May 20 @ 4:03 pm
          i really like this skin! thanks for the great work! using it almost everyday :) greetings from germany.
    geposted Mon 04 May 20 @ 1:21 pm
          thank you very much for u work DJ DennYo I never see a great work this is  Awesome and I am very delighted with your project
God bless you!!!!
    God bless you!!!!
geposted Tue 05 May 20 @ 2:00 am
