hi, using virtual dj 8 on MacBook pro. files on external HD not loading. sometimes when typing in search bar they come up but sometimes not. Don't list in box under search bar though. any ideas?? thanks
geposted Thu 26 Mar 20 @ 1:01 pm
Probably better if you add your folder, instead of the whole Volume as bookmarked folder (favorite folder).
Works then?
geposted Fri 27 Mar 20 @ 1:16 am
If you still have problems, check if somehow the software doesnt have access to files and folders
Typically something like this, but for VirtualDJ as the app
https://nektony.com/duplicate-finder-free/folders-permission
geposted Fri 27 Mar 20 @ 1:33 am
