HAVING PROBLEM OPENING UP THE VIRTUAL DJ
geposted Fri 27 Mar 20 @ 4:24 am
Do you seriously think anyone can help with that limited information?
Have a little think about the information we might need and come back again.
geposted Fri 27 Mar 20 @ 7:53 am
not typing in all caps either.
geposted Fri 27 Mar 20 @ 8:05 am
Try rename or delete settings.xml in /documents/virtualdj/ folder.
Works then?
geposted Fri 27 Mar 20 @ 3:07 pm
