Hi Guys, Every time I open the latest version of VDJ it opens as a tiny screen on my MAC. So small I can't expand it. If I do manage to get it to expand the green + window sizer seems to reduce it to tiny again.
geposted Tue 07 Apr 20 @ 11:10 am
geposted Tue 07 Apr 20 @ 11:34 am
Somehow you changed the size a lot, possibly by switching between monitor dpi or resolution to a very high one.
If you can reach it, just drag bottom right corner of the interface, and resize to any size you want, and this will be remembered ;-)
So it wont be that tiny again ....
(or delete settings.xml in /documents/virtualdj/ .. .that should fix it too)
geposted Tue 07 Apr 20 @ 1:25 pm
Open settings by pressing SHIFT+ESC on your keyboard.
Find the setting VideoWindowPosition
Delete it's contents
Restart VirtualDJ
Restart VirtualDJ
-- SHIFT+ESC on your keyboard
-- Interface
-- Maximized - Change it to 1
This will reset display to max on monitor.. Then you can grab the corner and adjust to different size as needed
-- Interface
geposted Sat 26 Dec 20 @ 9:50 pm
I am running Windows 11. I have loaded the Virtual DJ 8 software but when I open it only a small black box with a section of the screen is displayed? Please help
geposted Sat 24 Jun 23 @ 11:28 am
