I still have mac Mohave because i am SO afraid to lose my playlists (not my music, the actua playlists!) that took me 10+ years to put together. I also have only used VDJ by using my Itunes folder and then my playlists from there. PLEASE tell me if you have upgraded, and you use your playlists from itunes still? DID they dissapear? was it a clean upgrade? You can also recommend other playlist/music apps that I can start trying as an alternative BUT how can I use them with my exact playlists I have already built in itunes?
geposted Mon 13 Apr 20 @ 8:00 pm
