HI
Working all ok yesterday now comes up with cant open cant find skins library reinstall go to reinstall from website put in serial no and comes back already registred wont let download help
geposted Sat 18 Apr 20 @ 10:59 am
Did you try rebooting could just be a file locked stopping vdj loading that will clear once rebooted usually no need to reinstall
geposted Sat 18 Apr 20 @ 11:01 am
oldsoul55 wrote :
HI
Should also be able to find the installer here, since you have already registed the serial to your account :
https://www.virtualdj.com/users/licenses.html
Click the "old discontinued product" bar to see older products, if you have an old version of LE
geposted Sat 18 Apr 20 @ 11:32 am
And should also be available here:
http://www.virtualdj.com/le/
With your Wego LE license, you should be able to download VirtualDJ 8 LE there
geposted Sat 18 Apr 20 @ 11:36 am
