is there any way to update a skin that not on the download page? There some things I would like to add to the skin to make it update to VDj-2020.
geposted Sun 19 Apr 20 @ 4:40 pm
Yes you can update any skin. All you need is an editor for the XML. For PC, Notepad++ is the tool of choice.
Older skins also use bitmap files but that's not as necessary as it once was, since Atomix introduced vector graphics.
Vector graphics can be added to older skins without messing about drawing bitmaps.
Which skin do you wish to modify, and in what way?
geposted Sun 19 Apr 20 @ 4:58 pm
Does anyone know of a free skin for v8 basic that includes separate eq crossfaders (like mixlab 3.1) please? Unfortunately mixlab 3.1 is only available for the plus/pro versions. Thanks in advance!
geposted Sun 26 Apr 20 @ 7:15 am
