Topic: Play Lag on certain Tracks
First off, let me start off by saying I am in love with this software. It has everything you could possibly want!! However, I am getting play lag on certain tracks. It's not the song your mixing, it's usually the song that is playing. The two songs mix perfectly until the song hits a certain spot. It causes any track you try to mix with it to skip a part when you hit play. Hitting cue and holding it, it matches perfectly. Is there a bug in the way the song is? I tried loading different file versions and you get the same effect. Any suggestions on how to resolve this? The song I am using is Lil Suzy - Take me in your arms (Club Mix). No matter what I try to mix with it, the lag happens.. There are many other songs and BPMs that cause this happen, that is just one of them.
geposted Sun 26 Apr 20 @ 10:37 pm
geposted Sun 26 Apr 20 @ 11:08 pm
