Forum: Addons
Addons comments
Topic: Denon DJ SC5000 Screen
geposted Tue 28 Apr 20 @ 11:22 pm
Looking at the skin images posted by DJWORX, it's clear that the bottom and/or right edge of some numbers is being truncated.
Most obvious here is the (bottom edge of) elapsed time:
If you look closely at the right edge of some other numbers (i.e. loop roll 1/16) it's also truncated.
N.B. This is true across the range of Prime skins, not just the SC5000.
geposted Fri 21 Aug 20 @ 9:50 am
No response. Did this get looked at / fixed?
geposted Tue 08 Sep 20 @ 9:45 am
Mac only. Will be fixed soon.
geposted Tue 08 Sep 20 @ 1:28 pm
tenia mi set dj tirado desde marzo , ayer le saque el polvo , las conecte con virtual dj y quede impactado , funcionan perfectas!!! gracias al equipo VDJ
geposted Tue 15 Sep 20 @ 4:36 pm
It still not working here. The zip file of DJ SC5000 looks to be empty (only 84 kb).
geposted Thu 17 Sep 20 @ 8:48 am
No luck with Virtual Dj finding the interface ( skin) on the INTERFACE menu , after installing from extensions. Anyone else having issues ?
geposted Thu 05 Nov 20 @ 2:06 pm
It won't be shown there, because it's a skin for the SC5000 not the computer.
geposted Thu 05 Nov 20 @ 2:13 pm
Version 2 is available.
Changelog
  • 3 Views available (Controller Deck , Controller Deck + Sub-deck, 2 sub-decks). Can be selected from Screen skin Settings (hold VIEW button) or use SHIFT+VIEW to cycle through them.
    - Controller Deck view : You get the Deck defined by the LAYER button
    - Controller Deck view: You get the Deck defined by the LAYER button, plus an extra Deck that you can choose by tapping it's Deck Letter (or - if empty). This is mostly used if you get other single-deck controllers for Decks 3 and 4 and you wish to get their info on the SC screens.
    - 2 Sub-Decks: You get 2 Decks that you define by tapping on their Deck Letter (or - if empty). In this view the LAYER button will not affect the Decks you see on screen. This view is useful if you have a single Denon SC device and you want to control both Decks with the same device but keep both decks on screen.
  • Added Beatjump size on screen. With default mapping, use SHIFT+BEATJUMP buttons to select a different beats size.
  • Ability to see the Master Deck waveform along with the controlled Deck's one. Tap on the waveform icon at the left side of the scratchwave to get a menu to choose.
  • Wave zoom buttons moved in the waveform menu. Zoom can be done using SHIFT+BROWSE encoder in default mapping
  • Fixed truncated BPM and Time texts on Mac
How to install ...
1. Delete Denon SC5000 Screen.zip from /Documents/VirtualDJ/Skins folder (if exists)
2. Connect your SC 5000/6000/M device to your computer.
3. Start VirtualDJ
Screen skin will be automatically downloaded and installed.
Notes !
- Requires Build 6156 or later
- Use factory default mapping for your Denon SC devices.
geposted Mon 16 Nov 20 @ 5:49 am
Can you post some screenshots please, to show the three different views?
geposted 2 days ago @ 12:21 pm
