Topic: Waveform and Time?
Two really basic questions 1) how can I split the waveform per deck on the screen, vs having them lay one on top of the other? Can this only be done with certain skins? Seem to remember having it this way before, but want to know if possbile, 2) how can I change the time clock in the upper left of the screen to NOT show 24 hr clock when starting up, instead of having to click through it each time.
geposted Wed 29 Apr 20 @ 10:00 pm
1) yes, totally a skin thing
2) follows your computer. But you can override in settings, look for clockDisplay
thanks for the feedback. Any knowledge if the Denon 4500 controller Pro Skin Forever allows the split wave form? or is there a way to write the option into the program?
