Topic: Roland Dj707m Tr Drums issue
Hi all, I am having an issue with VDJ and my 707m that others have mentioned in the past e.g. "There is an issue with the TR sampler at the moment. When you press PLAY on the TR deck, and the TR is synced to another Deck (the MASTER one) , you may get the sample stutter at the beginning (and only then). This will be fixed in a future update."
Is there any update on this. It is a real pain with anything other than a simple beat as the drum pattern is then out of time. It seems to play the first bar and then repeat it before continuing with the rest of the pattern! Any help appreciated. Thanks.
geposted Sun 03 May 20 @ 3:38 pm
excit1PRO InfinityMember since 2022
I experience exactly the same issues... almost 2 years later.
The TR part of this Dj707m controller was for me a very important factor to make me buy it.
Received it some days ago, updated firmware and started checking out its communication with Vdj.
So far it´s the only issue, hoping it will ever stay the only one!
geposted Mon 11 Apr 22 @ 12:37 am
