Forum: Addons
Addons comments
Topic: Denon DJ Prime 2 Screen
geposted Sun 03 May 20 @ 4:34 pm
is that a skin for vdj?
or is this the release of the screen and Jogwheel Artwork from the controller with vdj?
geposted Mon 04 May 20 @ 10:01 am
It’s for the controller.
geposted Mon 04 May 20 @ 10:06 am
Really?? It's the screen installer and the jogwheel installer. In other topics they say no. It's not released..
geposted Mon 04 May 20 @ 4:38 pm
They also say that it will automatically download and install when you connect the controller.
If it doesn't then it's not available yet.
geposted Mon 04 May 20 @ 4:45 pm
New updated version 2.0 for Prime 2 Screen skin.
  • Added Horizontal Wave view
  • Ability to hide Wave completely (larger Browser)
  • Added Beat Jump value (requires Build 6154 - currently as Early Access - and default mapping)
  • Added clock
  • Added Beats number on waves (setting)
  • Added BPM Edit panel (long press of SLIP - factory mapping)
  • Changed Sideview button (shows selected view)
  • FX 3rd Param display (default mapping)
  • Fixed Time and BPM values truncated on Mac
Will be available as Update in VirtualDJ Extensions soon, but you could also delete the zip file from /VirtualDJ/Skins folder and will be automatically download the latest update.
geposted Tue 03 Nov 20 @ 4:59 pm
Thanks
geposted Tue 03 Nov 20 @ 5:03 pm
djaykcHome userMember since 2020
When I Use this skin on my:
MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
2.3 GHz Dual-Core Intel Core i5
8 GB 2133 MHz LPDDR3
Intel Iris Plus Graphics 640 1536 MB
I have issues with this skin slowing the interface down terribly... the music plays fine.... even the waveforms lag terribly... when I deleted this skin, the Prime 2 worked as a regular controller without the functionality of the screen....
I use an official usb-c to usb 3.0 to connect my prime 2 to my MacBook...
is there something I'm doing wrong....
v8.5 b6106 is my VJ version
geposted Fri 06 Nov 20 @ 9:33 pm
